I’ve just purchased a My Book Studio II 4TB drive and have set it up in RAID1, giving me a single mounted drive, 2TB in size.
I would like to know if I can use Apple’s Disk Utility to partition this 2TB drive into 500GB and 1.5TB partitions? Will the RAID1 mirroring still work if there’s more than 1 partition?
I can’t speak to whether WD’s RAID Scheme supports multiple partions or not. I’ve seen just as many posts saying its possible than I have of those saying its unsupported and doesn’t work.
However, you can play it safe and use Disk Utility to set up a 500 GB Disk Image and a 1.x TB Disk Image using the remaining space. This will produce your desired result.
I had the same question about a WD Thunderbolt Duo configured Raid 1.
I tried using the Mac disk utility to partition the drive with no luck. As soon as I reconfigured the drive, the RAID would detect an error and rebuild.
If anyone has an elegant solution, I’d like to read about it.
