Hi there,
Just wondering if my m240 can play mp4 files. If not, can you point me to a program that will convert it to mp3?
Hi there,
i can tell you it wont play mp4, dont know of any programs though…sorry
M4P to MP3 Conversion Methods
There are two other methods to convert M4P to MP3 by bypassing the DRM control. The first method is to burn a copy to an audio CD and then rip it. Some software products take an even simpler and more automated method which allows user to burn music to a Virtual CD-RW disc and then automatically rip and encode the music stored on the Virtual CD-R. NoteBurner M4p converter is the typical example which uses this Virtual CD-RW drive method.
The second method is to use a recording software and sound card (utilizing the so-called “analog hole”).
