Hi at all, I have a new SSD SanDisk Ultra 3D from 1 TByte.
Now I want migrate Filesystem with Operating System (Windows 10) to SSD, which program can i use ?
Thank you very much
Thank you very much
download and install the sandisk SSD Dashboard. Once installed on the tools tab you can download and use the acronis cloning software.
Hi Roma04,
You can check on this website, this will help you in knowing the right program to use as well as the steps on hoe to do it. Hope it helps.
https://www.easeus.com/backup-utility/migrate-windows-10-to-ssd.html
How to install new year wallpapers for free
