MicroSD Card in Phone Keeps Saying "Removed Unexpectedly"
Not sure what happened, was listening to music fine this morning on my phone (LG Optimus F3). Then a message popped up today saying “The SD Card was removed unexpectedly. Be sure to unmount first to prevent damage” or whatever. Then it would scan the media. Then after a few minutes it happens again and repeats. I’m not even touching the SD Card.
I unmounted and took it out and put it back in. but its still happening so I just took it out now. Anyone else have this issue?
in that case you can try to format the card with the pc using the disk managment. if this does not resolve your issue you can contact the sandisk support to replace the card in the warranty or you can go to the place of purchase for a possible replacement there.
