how can i transfer video and photos from my micro sd card on my samsung phone? is there a way to load them to my laptop?
Put the memory card into a card reader (with an adaptor if needed)
then plug the reader into a USB port on your laptop. Copy to the location of your choice.
Most laptop have built in card reader installed. If does, you can just get an adapter.
Aside from using a card reader. You can also access the data on your card, with the Infrared connection, Bluetooth, and with USB or data cable.
I would like to transfer the pictures on my phone card to my computer so I can print them .
