failed to read the backup information on 32gb sd card since upgading to android 4.4
Failed to read the backup information after upgrading to Android 4.4?
Before upgrading, can you see that information?
yes it worked fine before. Decided to use a freeware backup and works fine
I have the same problem . After I updated to Android 4.4.2 kitkat memory zone became useless for me . And I loved it before . Wish I could go back to 4.3 – sigh
I just installed an Extreme 32GB card in my Samsung S4 phone and downloaded the Memory Zone app. It gives an error (Failed to read the backup information. Next backup: %1$s. %1s on %2$s.) whenever I try to backup.
I had the same problem for weeks (with different phone and Android version), but I fixed it by uninstalling the app and then reinstalling it. It certainly couldn’t hurt for you to try that. I hope it works for you.
