Hello everyone. I want to a safe MBOX to PST Conversion with MBOX Converter but I didn’t recognize the best software to convert MBOX files to PST. On Google, there are several solutions to convert MBOX files to PST. Does anyone have the best solution? Please suggest to me the safest solution for MBOX to PST Conversion.
There are many ways and means on the web that help you convert MBOX to PST file format. So, I discussed a few methods, and how to use them to convert your MBOX file to PST format.
Step 1: Export EMLs from MBOX in EML Format
- Using Thunderbird:
- Open Thunderbird: Install and open Mozilla Thunderbird.
- Add MBOX Account: Set up an account and import the MBOX file into Thunderbird.
- Export Email: Select the email or folder you want to export, right-click, and select “Save As” to save as an EML file.
Step 2: Import EML Files into Outlook
- Using Microsoft Outlook:
- Open Outlook: Launch Microsoft Outlook.
- Create a new PST file: Go to File > Account Settings > Data File > Add, and create a new PST file.
Drag and drop EML files: Open the folder containing the EML files and drag them to the appropriate folder in Outlook (e.g., Inbox).
Some users with technical expertise may find the mentioned method helpful, but those without technical knowledge often encounter issues such as complex steps, file limitations, and the risk of data loss. To address this situation, an automated program like Softaken MBOX to PST Converter Software can be used for safe and secure conversions. This software enables easy conversion of bulk MBOX files to PST format without any limitations or restrictions, making it accessible for both tech-savvy and non-tech users. Furthermore, the advanced program is compatible with all versions of MS Windows OS.
When we talk about best MBOX to PST tools, I’ll always go with BLR MBOX converter tool. Because sometime ago I used this software to convert my MBOX files into PST and I got best solution. It makes my work easy. In the start, I used its free version
Thank you so much, Emma, for giving me the latest tool for MBOX to PST Conversion, I can convert my MBOX files in 30+ formats with this single tool.
For best results, it is highly recommended that users go with professional application software. Mailvita MBOX to PST Converter for Mac software is a free way to convert MBOX files to PST format in just a few easy steps. The tool allows users to export multiple, select, and filter mailboxes from MBOX files to Outlook PST file format. It seamlessly preserves all data quality, integrity and structure in a new PST file. It extends support to include Eudora, SeaMonkey, Thunderbird, Pocomail, AppleMail, Entourage, Spicebird, Opera Mail, Evolution, and other email programs that handle MBOX files. It supports both Mac and Windows OS versions. The free demo version of the software converts some emails from MBOX files to PST format.
