Hi, I am Anjali Agarwal. I have a question on MBOX to PST Converter… Recently I needed to convert my friend and my 25+ MBOX folders to PST format but I couldn’t find any good and accurate MBOX to PST Converter tool that has the latest features and is also enough for me. I need a recommendation for every user who can suggest the best and free MBOX to PST Converter as per features for new users.
Hi, @anjaliaggarwal I hope this will help you out!
BLR MBOX to PST Converter is a specialist program that allows Windows users to convert MBOX files to PST format. This tool helps users migrate from email clients such as Thunderbird to Microsoft Outlook, assuring a smooth handover of email data. This BLR MBOX converter offers batch conversion, allowing users to convert numerous MBOX files at once, saving time and increasing productivity. The UI is user-friendly, making it accessible to those with less technical skills. It also preserves the integrity of the original data, including attachments and metadata, guaranteeing that no information is lost throughout the conversion process.
If you are looking for a tool to convert MBOX to Outlook PST, the professional Softaken MBOX Converter Tool is perfect for you. It is a unique tool with various advanced features that make it easy and accurate to convert MBOX files. This tool enables the conversion of multiple MBOX files at once without data loss. Moreover, you don’t need any technical guide as it has an easy-to-use interface. This software offers a secure and hassle-free solution for converting MBOX files to PST format.
The simple steps to convert MBOX file to PST using this tool are:
- Download and install the MBOX Converter Tool on your PC.
- Click the Add File or Add Folder option to add MBOX files.
- Then, select the desired file you want to convert and click Open.
- View your email file attachments and click the Next button.
- Then, select PST as the saving format and apply any options required.
- Click the Convert option.
Hi, @emmatf I am not a technical person, as I mentioned I need to convert 25+ folders of MBOX files to PST format. With this BLR MBOX to PST Converter can I convert multiple MBOX files to PST? Because I want to save my time on MBOX to PST conversion…!!
Will BLR mbox to pst converter be a proper and safe solution for mbox to pst conversion… can you confirm it…!
@anjaliaggarwal Yes, it will help you to save your precious time by converting a large number of files there are no limits! This software only takes time when you convert many MBOX files to PST at one time. Go ahead and convert unlimited mbox files.
I suggest you take the demo of Stellar Converter for MBOX, the advanced tool that helps you convert the MBOX file to PST without any effort. With the help of the tool, you can convert more than 18+ email clients’ data to PST, such as Thunderbird, Google Takeout, Apple Mail, Opera Mail, etc. You can easily convert the data from all these clients to PST as well; software allows you to migrate it to Office 365 without adding too much effort.
Note: At his latest release, it becomes more powerful by adding the two special features, like the fact that you can now access the MBOX contacts and calendar items and convert them to the desired file format. To know more, you can take the trial of the tool now: MBOX to PST Converter tool to Convert MBOX file to Outlook PST.
