I’m using a camera app that saves both jpeg and dng file, the file number is the same but the extension differs. It seems like the copy function of the iXpand app does not look at the extension, only the file name and therefore all my files are being renamed to avoid duplicates. Jpeg IMG_8001 is renamed to IMG_8001~photo and the DNG file is then renamed to IMG_8001~photo-alt. A movie clip from a Live photo is renamed to IMG_8002-video-paired.
Is there a way to change this in a setting or would this require an update?
I would also like to know the answer to this! Super annoying feature.
