if u know something kindly inform me or give me some links…
ive tried to search it on the box up there but no results was found.
tnx
tnx
I think the problem is with the Clip’s small size. It doesn’t have the 30-pin connector port like the other models do, so it can’t be adapted to the same docks that support the others. Designing a docking station for just 1 model from just 1 manufacturer wouldn’t be very lucrative, I’m afraid.
Having said that, you can always Google it. Just becasue nobody here has heard of one, doesn’t mean one doesn’t exist.
Good Luck! ![]()
