Anyone have any ides about how to transfer iTunes movies to Sandisck Micro SD Card for Playbck? I really appreciate if someone can show me the detailed steps.
I am afraid it can’t be transferred directly, you can use an iTunes video converter to help you remove DRM, then there won’t be any problems and you can play the iTunes movies freely as you want.
The itunes movie can only playback with iTunes program or APPle devices. If you want to play on other devices, you’d better to remove the DRM restriction from the iTunes movie. You could view more about this iTunes movie DRM tool to get more info. More about DRM protection please refer https://en.wikipedia.org/wiki/FairPlay
The iTunes is a powerful application that enable Apple users to store files, play music and manage the device. You can follow the steps below to transfer movies from the iTunes to computer.
Firstly, connect the iPhone to computer with the USB cable and then start the iTunes on your computer. Just hit the “Edit > Reference … > Advanced” option.
Secondly, click the “Copy files to iTunes Media folder when adding to library” button and then when you sync the files from iOS device to the iTunes library, the media files will be automatically saved in the folder.
Then you could sync the movies from computer to Sandisck Micro SD Card.
I don’t think it is will work, as there might be an incompatibility issue.
