Yes, it’s possible to recover data from a failed SSD, depending on the type of failure. For minor issues like corrupted files or accidental deletions, data recovery software such as Disk Drill or EaseUS can often retrieve lost data. However, if the SSD has experienced physical damage or severe hardware failure, professional recovery services may be required. These services use specialized tools to recover data directly from the memory chips. It’s important to note that SSD recovery can be more challenging than traditional hard drives due to the way data is stored on flash memory.
@harry_roy Have you checked our knowledge base articles?
(Get Support for Your SSDs and Flash Products | SanDisk)
Try this one.
(Contact Support | SanDisk)
I know I’m a bit late to this, but I wanted to share my experience to help others facing the same issue. I recently had a similar problem with my SSD – I had backups, but they weren’t accessible when I needed them. After researching and trying a few options, I found success with a data recovery software called BLR Data Recovery Software. It made the recovery process incredibly straightforward and managed to retrieve all my data efficiently. So, for anyone dealing with an SSD failure, I highly recommend giving it a try!
Yes, data can be recovered from a failed SSD. For logical failure, data recovery software like Stellar Data Recovery, Recuva, Recoverit, and so on can help. If there is a hardware issue, then you can go for professional data services as needed. If the SSD is functional, then try data recovery software first.
(post deleted by author)
Get a USB stick or USB hard disk and use it to backup personal files. I use USB hard disks which have lots of room.
Yes, data recovery from a failed SSD is possible in many cases, but success depends on the failure type:
Logical Failure (e.g., accidental deletion, corruption, formatting):
Try data recovery software like 4DDiG Data Recovery—I’ve used it successfully on SSDs with corrupted partitions. It supports deep scans for lost files without overwriting data.
Firmware/Controller Failure (drive not detected):
If the SSD isn’t recognized at all, you may need professional recovery services (e.g., DriveSavers).
Physical Damage (e.g., NAND wear, PCB issues):
DIY recovery is risky; consult a lab if data is critical.
If the SSD still shows up (even with errors):
Immediately stop using it to prevent further damage.
Connect it as an external drive (via USB adapter) and scan with recovery tools.
4DDiG is worth trying for logical issues—it’s less aggressive than some tools, which helps avoid further damage. Just be sure to save recovered files to a different drive!
(Note: For hardware failures, avoid freezes/heat methods—modern SSDs don’t respond like HDDs.)
Yes, data recovery from a failed SSD is sometimes possible, depending on the failure type:
Logical errors? → Try recovery software (e.g., Recuva, EaseUS).
Not detected? → Check BIOS, try a USB adapter, or update firmware.
Physical damage? → Requires professional recovery (expensive, not guaranteed).
Key Limitations:
TRIM/Garbage Collection may permanently erase deleted files.
Encrypted SSDs (e.g., BitLocker) need the key.
Here’s a full guide about crashed SSD data recovery:
Best Action: Stop using the SSD immediately and consult a pro if data is critical.
Like I have said before, make copies of valued data and do not depend on one storage unit to be perfect
Your conclusion is a bit misleading. On SSDs with TRIM enabled, recovery tools like Disk Drill or EaseUS won’t really help.
Don’t believe it? Try it on a Mac yourself: delete a file, empty the Trash, and then run one of those recovery apps. You’ll see they only find what’s still on your drive—not what you permanently deleted.
If your SSD has important data or is showing signs of hardware failure, don’t keep using it. The best move is to clone the entire drive and then send it to a professional data recovery service.
u can use a professional data recovery tool like:pcgogo data recovery
In modern operating systems (Windows 7+, macOS, Linux), the TRIM function for internal drives is enabled by default. If an SSD gets corrupted, the chances of recovery are very low.
For external SSDs connected to a computer via USB, if logical damage occurs, such as displaying error messages like “raw,” “unallocated,” or “must be formatted,” you should use data recovery software as soon as possible to save recoverable data to another safe location, such as your computer or another working external USB/SSD. Also read - Hard Drive Data Recovery: Recover Lost Data & Repair Hard Drive Problems
