Can I use a SanDisk Connect Wireless Stick Flash Drive to transfer files (photos, documents) to/from a Windows PC and my 2018 iPad Pro 12.9 running IOS 12.1 and the Sandisk app (while I believe this is compatible on the the Windows PC side, I’m concerned with file system compatibility on the the iPad, which may not support exFAT, FAT32 or NTFS)?
it will work with the iPad pro. the wireless stick uses FAT32 for 32GB and below capacities and exFAT for 64 and above. The app communicates with the stick so file system is not an issue. NTFS cannot be used as it is not compatible with the app.
