Hello, from the upgrade from 10.3.3 to 11.0 the ixpand works (with the app already installed).
However, if you erase all contents and settings, and then install the app you get an error message to connect.
Failed to connect to Iexpand drive. Please remove and reattach.
Then going back to 10.3.3 the iexpand works fine.
Any suggestions or is the app held in the store doesnt work the problem.
Both things happens on an ipad 2017 (5 gen) and an iphone 6. and with two ixpand drives. Both work on 10.3.3 and on the pc.
