Must say thath the instructions in the manuall isnt matched how the reality works when it comes to remove
a song from the Go list once its added in the Sansa Express
*Select Playlist
Select Go list
Press <<or >>button to select song
Press Submenu
moce down to remove song from playlist*
remove sound from playlist doesnt show us as a alternative
only clear playback list…not really what i want
There is after all only 2 buttons thath can even be of question to be correct one here?
thath 10 & 11 aka Submenu/down ore Select
Submeny goes back to where you started and select just says “allredy in the go lost”
how shall i press? ore isnt it even possible to remove with this modell?
skyl
2
Spelling, and second, what are you asking about?
**bleep**…Im sorry a word falled away as usual
“Remove sound from playlist” doesnt show up as an alternative
only clear playback list"
that is the problem basicly, thath function no-where to be find.
Can you please give me the correct press-button-order u use to find it?
cause the manual seem to suggest wrong?
skyl
4
So you’re trying to remove a individual song from the playlist?
There isn’t a function like that unfortunately. This wasn’t a feature on the “m2XX” series either.
Aha i see, well seens it stood in the following manual of my player i was convinced there should have been
for my modell
thanks for replying
Then why does the manual say there is? The manual for the Sansa is so full of errors it is unusable.
