Removing song from Go List
How do I remove a song from my Sandisk Express Go List?
highlight the song that is on the go list, press the submenu button(down) then select ‘clear go list’
When I did this, it removed all the songs from the Go List. How do I remove just one song from the Go List.
when the song you want to remove from the go list is playing press and hold the center select button. you should recieve a message asking you if you want to remove the song from the go list. select yes and the song will be removed.
