imac and rhapsody installation cd not compatible!
hi , please help, it turns out that my imac wont take the small rhapsody installation cd of my Sansa clip+. is there anything i can do? i want to try rhapsody. it also says i can only access features with rhapsody cd installation?
http://forums.sandisk.com/t5/Clip-Clip/Signup-to-Rhapsody-required-for-all-features-to-work/m-p/207586#M33185
If you dead-set on using the mini-CD, you’ll have to use another machine. Apples are great stuff, aren’t they?
In looking at the Rhapsody site, the system requirements still don’t support the Intel based Mac. So if you have a 3 inch CD, it won’t work with your Mac in more ways than one. I just switched back to the PC, but in my almost 3 years with a Mac, Rhapsody, a part of Real.com, refuses to move forward with Mac support. Bummer!
thank you so much i will try that, i am so bad w/ this kind of stuff. great we have sites like this.
that really ■■■■■ because so many people have Macs we just got this imac this year and love it . thanks for the info i will try it anyway from their website
Really? Last I knew, they were still under 10% of the overall computer market.:stuck_out_tongue:
i dont think so, but what i do know?
