Am using 64gb its workubg fine on my pc i fomated it and it has files on it now ot doesnt wana play on my car radio and smart tv i need those drivers please
I believe that the issue could be due to the file system format rather than missing drivers. Most car radios and smart TVs support FAT32 or exFAT, but NOT NTFS. So, you need to reformat the USB Drive to FAT32 or exFAT.
Also, make sure your music files are in a supported format like MP3, WAV, or AAC.
As @Ellinor_William mentioned, the issue is likely due to the file system format. Most car radios and smart TVs don’t support NTFS, so you need to reformat the USB to FAT32 or exFAT. Follow the steps below to fix it:
- Back up your files, as formatting will erase everything.
- Open File Explorer, right-click your USB drive, and select Format.
- Choose FAT32 (better compatibility) or exFAT (for larger files), then click Start.
- Once done, copy your music files back and try again.
Your 64GB USB works fine on your PC, but it won’t play on your car radio or smart TV. Try formatting it to FAT32, as some devices don’t support NTFS or exFAT. Make sure your files are in a compatible format like MP3 or MP4. Avoid special characters in file names, and try using a different USB port. If it still doesn’t work, test with another USB drive to see if the issue is with the device. No extra drivers are needed.
