How To Use SanDisk Secure Access and How to Use It
SanDisk Secure Access is a really good way to protect your data both on the device where you are storing it and when in transit. It also gives you the peace of mind that it’s encrypted, making it impossible for anyone to access your personal information without permission.
If you’re not sure how to use this app, here’s how: To use SanDisk Secure Access, all you have to do is open from within the app and store your data with some security settings enabled. If updates occur or if events happen (e.g., you’re unlocking a phone that’s been remotely locked), SanDisk Secure Access will keep your data safe. To do this, all you have to do is use a fingerprint or a passcode. Or if your device doesn’t support fingerprint scanning, use a PIN, password or pattern to secure your information.
With encryption on, the only way someone can see the sensitive content of your data is if they know the password or pattern. This means that when you allow for automatic app updates, you will never get a warning saying there’s an issue with an app storing data that isn’t encrypted. If you have Secure Access installed and enabled on your Android device, your device automatically encrypts new data. You don’t have to worry about it – SanDisk Secure Access takes care of everything for you.
To learn more about how to use SanDisk Secure Access and how to use it, visit the link below:
http://www.sandisk.
Hi @carmechanics,
