Can I replace a hard drive from a My Book external drive I purchased?
If yes, is there any documentation on your website?
Thanks,
Noor
Thanks,
Noor
You mean the internal hard drive in the my book? I would guess that is not possible. Try calling tech support to see if you can replace it. You can also check the link below for help.
http://wdc.custhelp.com/app/answers/detail/a_id/8/session/L3RpbWUvMTM1NzI1MzU2Ni9zaWQvNVZCTWNwZmw%3D
Are you trying to replace the drive in the PC with the one from a My Book?
Joe
I have a similar question. The hard drive of the WD MyBook Essential 500GB is died (not a WD fault, it’s user error, if you understand
). Can I put a new hard drive into it? Of course, the MyBook Essential does have only one disk, no raid, etc. Or, can I use larger disk? For example a 2TB disk, instead of the original 500GB?
