My 500 Gb Mybook Model WD5000H1CS-00 is full and I have a simple question. Can the internal hard drive be replaced with a bigger hard drive?
If so, is there any specific drive that I should use?
Thanks!
P.S. The drive is no longer under warranty.
Thanks!
Hi there, the external case from MyBooks tend to work only with the original drive that came inside… So chances it’ll work are low.
If I were you I’d get a universal case and the largest compatible drive I could get ![]()
