i have problem with my SANDISK,USB FLASH-DRIVE(8GB) that whenever i insert or plug it with some computer and try to write(CUT,COPY etc) it shows an error that THE DISK IS WRITE PROTECTED…can any one please suggest that why it is displaying such error…at first i think that this is problem with my pc but know the essue is same for all computer…
can any help me to resolve this issue???
Have you read any of the previous replies in this thread?
I bought new sandisk 16gb usb pendrive in that i cant able to save the files nor i cant format because it is showing write protection and i tried to remove that but it is not happending. Please suggest me how to do that
I have a SanDisk Cruzer Glide 128g and it is telling me that it is Write Protected, I did not place any write protection on the flash drive but it is there and now I cannot write anything to the drive. My first question is, how do I remove the write protect? And secondly, why is SanDisk putting drives on the market with potential problems for us consumers? Finally, the fix or repair should come from the company (SanDisk) not from us users who are experiencing the same problem. Where is SanDisk responsibility with this issue? Thanks and have a good day.
there is no fix. If it is showing write protected the drive locked it that way to prevent any possible data loss. Back up the data and contact sandisk support for a warranty replacement. if you have sensitive data on the drive let them know. they have a return process for that as well.
well if you guys having problem with finding ‘Storage device policy’
then go to the same path :-
Navigate to HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control
then simply press Ctrl+f
And type “StorageDevicePolicies” or “Storage Policies” any one that you like. it will take a little time
and eventually it will stop with highlited text without thinking hit Delete or Press right click and choose delete and then
try following
Step 2:
insert the USB device, then
control panel->Admin Tools->Disk Management
Your boot drive will show as C:\ and under
Layout will be Partition
File System will show NTFS
How does your USB show up?
Step 3:
So if you go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control
look for StorageDevicePolicies – if found, open it and look for WriteProtect - - delete the key
Step 4:
Try this …it definitely works…I found it after lot of research online…
i m really happy that i got my pendrive back. in working condition.
If you cannot copy, delete or send data from your pen drive or face problem when you format it. It shows en error message like “The disk is write protected. Remove the write protection or use another disk.”
Basically write protection allows a pen drive to keep its content from being changed.
Number of Methods to fix write protection error on pen drive
Best ways to remove write protection error from your pen drive goes here:
Fix Error through Registry Editor
Go to “start” option of your computer and open Registry editor
For this you write a command “regedit” on run
When registry editor open, navigate the location: HKEY_LOCAL_MACHINE/System/CurrentControlSet/Control/StorageDevicePolicies
In right side you will get a value named “WriteProtect“. Just right click and change the hexadecimal value from 1 to 0 and you got it. You have safely remove the write protection error.
Exit registry and restart your Operating System
Then connect your USB on PC
Note: If the value named “WriteProtect“ does not exist then follow same steps which is mentioned above , but change “HKEY_LOCAL_MACHINE” with “HKEY_CURRENT_USER“.
