How to recover my lost data
If you are searching for ways to recover lost data, right data recovery tool can make all the difference. Whether you’ve accidentally deleted important files, formatted a drive, or faced a system crashed, using specialized software like a data recovery tool can help retrieve your lost information. This software works by scanning your data storage devices—whether it’s a hard drive, USB, or SD card—to find and recover deleted, lost, or corrupted files. It can handle various file types, including documents, photos, videos, and even system files, ensuring that no crucial data is permanently lost. The process is usually simple: install the tool, select the drive to scan, and let the software recover your files.
I suggest First connecting your SanDisk to another computer or device to ensure it’s not a device-specific issue. Otherwise, there are a few options for the SD card recovery.
You can try Stellar Photo Recovery, that’s the most reliable tool for recovering data from a corrupted, inaccessible, damaged, or formatted SD card.
Sometimes the data isn’t actually deleted but might not be readable by a specific device. Try connecting your memory card to another device (e.g., your PC) to see if the files are accessible.
On the other hand, your files might be marked as “hidden” or “system files” and are not visible. You can use the following command in the Command Prompt to check for them:
  • On Windows, open Command Prompt as Administrator.
  • attrib -h -r -s /s /d drive_letter:*.*
If you’ve lost your files, don’t worry. This article explains in detail how to recover lost data from an SD card.
If the mobile phone automatically deletes your files, you should stop using it and remove it from your mobile phone. Keep writing new data will overwrite your data.
Try EaseUS Data Recovery Wizard and perform SD card recovery now.
I had an SD card that suddenly stopped working, and I thought I’d lost all my photos. This tutorial helped me: How to Recover Deleted Files From SD Card [Updated] | PCWorld
Before recovering data from an SD Card. You really need to make sure you have a good destination for those recovered files. If you’re saving back to the same SD card you’re recovering from, you could risk overwriting the very files you’re trying to get back. I had to double-check my destination about five times because I was super paranoid about making a mistake.
To recover lost data, start by checking your Recycle Bin or Trash if files were accidentally deleted. Use data recovery software like BLR Data Recovery Tool suggested by @emmatf . Other tools are also available to recover files such as Recuva or Disk Drill for files that are no longer there. If the drive is corrupted or formatted, these tools can help recover data. For failed hard drives, try different connections or ports, and consider professional recovery services if there’s physical damage. On smartphones, check for backups or use recovery apps like Dr.Fone. If you’re using cloud services like Google Drive or iCloud, check if the data is available for recovery. Always avoid overwriting the drive to maximize chances of successful recovery. :innocent:
It sounds like your data might have been deleted due to a compatibility issue or improper ejection of the memory card from the previous device. When you switch a memory card between different devices, some devices might automatically format or delete files to optimize the card for their system. To avoid this, always eject the card safely from one device before using it in another. You can also try to back up your data regularly to avoid any potential data loss.
To recover, you can use a tool called Softaken Windows Data Recovery Software. This tool is 100% free and able to recover data from any storage device. I used this tool to recover data from my 128GB pen drive, and the software successfully restored all deleted and corrupted data files. Also, this tool supports every FAT type and NTFS file system so you can easily use this tool where you need it. I highly recommend trying this smart utility for data recovery.
