Today I lost my 1GB SanDisk Data How Can I recover it?
Hello people, in my SanDisk I keep my old memories and recently lost. Kindly some one give me some suggestion. What can I do to get back those data
I heard you lost your 1GB SanDisk memory card data. Sometime ago I suffer same time problem, the difference is I lost my huge amount of data more than 1Gb.
I am suggesting you to try…
Because this is the cause of my problem. Hope it’s also help you out. And solve your SanDisk data loss problem
Thanks for suggesting me about this wonderful software for SanDisk memory card data recovery. I get my all data. I purchase is 1 year plan at $100. Thanks…
I just shared my experience with you, but it’s good to hear that you got your data back.
In fact, there are many free data recovery tools available, such as recuva, testdisk, etc. And, RescuePro developed by Sandisk for its users. When you buy a Sandisk card, they usually give you a free license for RescuePro.
There are also some powerful data recovery software that provide users with free trials. You can try Tenorshare 4DDiG which allows free recovery of video and photo files. 4DDiG worked magic for me. It recovered files that not even RescuePRO could.
I suggest First connecting your SanDisk to another computer or device to ensure it’s not a device-specific issue. Otherwise, there are a few options for the SD card recovery.
You can try Stellar Photo Recovery, that’s the most reliable tool for recovering data from a corrupted, inaccessible, damaged, or formatted SD card.
Try some user-friendly SD card recovery software that can be your best solution. Most user-friendly recovery tools are paid, and you can find a product that offers a trial version or a limited free version and recover your SanDisk data.
I’m sorry to hear about your data loss. Here are a few steps you can try to recover your files from the SanDisk:
  1. Check for Physical Damage: Ensure the device isn’t physically damaged (e.g., cracked or bent). If it is, avoid using it further to prevent worsening the issue.
  2. Try a Different Device: Insert the SanDisk into a different computer or use a different USB port to rule out connection issues.
  3. Data Recovery Software: Use data recovery tools like Recuva, EaseUS, or Disk Drill to scan and recover lost files.
  4. Professional Data Recovery Services: If the above steps don’t work and the data is critical, consider reaching out to a professional data recovery service.
Remember to avoid writing new data to the SanDisk to prevent overwriting the lost files.
Rather depend on some flash memory, better is to backup photos and videos.
I use USB hard disks which have room galore to backup important data, I use a second disk for redundant copies.
First, please stop writing any new files to the external Sandisk drive and do not attempt to format it.
  1. Check the Recycle Bin: Open the Recycle Bin on your computer. If you find the lost files there, right-click them and select “Restore.”
  2. Show Hidden Files: Open File Explorer, go to the “View” tab, and check the “Hidden items” box to see if the data was merely hidden.
If the files are permanently lost, download specialized data recovery software to scan the external drive. Once the scan is complete, save the recovered files to your computer’s local disk instead of the original SanDisk external drive.
Read also - Recover Deleted Files on Windows PC Easily
