How to recover formatted hard drive!
Want to know about how can i recover a drive which is formatted as that data is imp. Kindly tell me ?
Do NOT write anything to the drive.
There are apps that can recover files on formatted drives, some are free, some are expensive, some are scams. If you can find a local repair shop take the drive to them to recover your files.
To recover data from your formatted drive, immediately stop using it, to avoid overwriting the data. Data recovery software like Stellar, Recuva, EaseUS, or Disk Drill can help you recover it, you just need to install it on a different drive. Most of them have a free trial edition that will let you know which software is helpful to you in recovering your data so that you can decide where to spend your money. If the software doesn’t work, then you can consider professional data recovery services.
Note: There’s no guarantee that a formatted USB drive can always be recovered.
In my opinion, successful recovery requires at least the following conditions:
  • Quick formatting.
  • No data overwrite occurred after formatting.
  • The USB drive is not physically damaged and can be recognized by the computer.
  • You have a habit of regular backups.
If old data is overwritten, recovery becomes almost impossible. That’s why the first step in data recovery is always to stop using the drive. Then, you should check for available backups, especially in cloud storage.
There are many free data recovery tools available, such as Recuva, Windows File Recovery, TestDisk, PhotoRec, etc. However, you only need data recovery software once in your lifetime. After that, you should learn how to backup.
Many articles mention using CMD to recover a formatted USB drive. This is incorrect. The ‘attrib’ command is only used to display hidden files and cannot directly recover a formatted portable device. The ‘chkdsk’ command, on the other hand, is used to fix file system errors and bad sectors.
Do not write anything new to the drive. Some data recovery software can recover files on formatted drives. These softwares can be free or paid. You can go for software like Stellar, Diskdrill, Recuva, Recoverit, Undelete and so on. If data recovery software is not able to recover the files then take the drive to a professional.
i did tried most of these software , Quite not satisfied with the result . I tried recuva , window recovery , BLR Tools. Happy to say that pen drive data recovery software help me to recover my data. I appreciate your help thankyou.
EaseUS, Free to Download and US$69.95 to Recover files.
I have formatted a SanDisk SD card, downloaded a recovery software, EaseUS, and it brings back most pictures I have shot with Canon 6D. You can try the same software to recover a formatted hard drive.
To recover data from a formatted drive:
  1. Stop using it to avoid overwriting.
  2. Use recovery software like Stellar Data Recovery, Recuva, or Undelete.
  3. Connect the drive and run a deep scan.
  4. Recover files to another drive.
  5. If that doesn’t work, contact a professional recovery service.
Recovering data from a formatted drive can be tricky and depends on how it was formatted. If it was a quick format, the data isn’t erased - just marked for overwriting - so third-party recovery tools can often help. However, if it was a full format or an SSD with TRIM enabled, recovery is nearly impossible since the data gets overwritten or wiped.
Here’s what I’ve used for different formatting cases:
  • Option A: Disk Drill – Paid, but highly effective for recovering data from formatted drives or file system loss across various file systems like FAT32, exFAT, NTFS, EXT4, and more.
  • Option B: Recuva – Free, but limited. It works best with FAT32 file systems (e.g., if you formatted a drive originally set as FAT32, though that’s less common). Results with more complex formats can be hit or miss.
When you format a drive (especially using a quick format), the file system metadata is rebuilt and the old file entries removed. The space previously containing old data is marked as available for new data. Although the old data may no longer be visible via the operating system, on many traditional hard drives the physical data remains until it is overwritten. In such cases, professional hard‑drive recovery software can often reconstruct the previous file system and recover files — although success depends on factors like how the format was done, whether new data was written, and whether the drive uses SSD technology (with TRIM/wear‑leveling).
Related how-to post: Hard Drive Data Recovery - Recover Lost Data & Repair Hard Drive Problems
Take a deep breath! It’s usually fixable if you act fast and don’t panic-write new data to the drive.
Here is the basic game plan to try and save your data:
Stop using the drive. Seriously, unplug it if it’s external. Every second it’s active increases the risk of overwriting your old files.
Get a recovery tool. You’ll need software to scan the raw sectors. easeus data recovery is a solid option for this because its UI is super clean and it’s really good at reconstructing formatted partitions.
Scan, don’t write. Run the software from a different drive, select your formatted hard drive, and let it do a deep scan.
Recover to a safe spot. When (hopefully) your files show up in the preview, recover them to a completely different external drive or your main SSD.
Type of format matters though—was it a quick format or a full format? If it was a quick one, you’re probably golden.
