Is there any way to get back deleted data that hasn’t been backed up?
I really need the data. Please help me
Yes there are few possible way, to recover data, can you tell when your data was deleted and after that how many you have used your disk?
I deleted the data on June 24 - 12:22AM and used it until today
I think it’s everyone’s dream to recover deleted information, it happened to me and they wanted thousands of shekels from me and it’s not certain that it will be restored!! If you have an answer to this, my congratulations are endless
Hi, I think you need a the professional tool to recover files.
"Hi, I apologize for the delay in responding! Since the data was deleted in June and the disk has been in use since then, the chances of full recovery depend on how much new data has been written to the disk. New data may overwrite the deleted files, making recovery difficult. However, you can try using Windows data recovery software, a reliable tool for recovering deleted files. It supports various file types and storage devices… I hope I was able to help you!
If you want to recover deleted data, you have to use a professional tool. Before buying the tool, you must check the tool’s reviews, and the tool also provides a free trial version.
Stop using your device right away to prevent overwriting the deleted files. Then run the recovery tool and scan your storage, you might be able to restore some or all of your lost data.
I apologize for my tardy reply; I know how upsetting it can be to inadvertently lose crucial data. It can be annoying when files are erased from your computer, USB drive, or external hard drive, particularly if those files contain important data. Thankfully, there are safe and efficient methods for recovering deleted data.
When data is deleted, the space is simply marked as available for reuse rather than being completely removed from the storage device. To avoid overwriting, do not add new files to that location. Using a trustworthy data recovery tool that thoroughly scans your drive and recovers deleted emails, documents, images, and videos is the best course of action. BLR Data Recovery Software works even if files are deleted, formatted, or lost due to system errors. To prevent additional data loss, always make sure to save recovered files in a different location. To avoid future accidents, regular backups are also strongly advised.
It has been a long time since it was used and after being overwritten multiple times, I don’t think it is possible to recover it.
I believe you still have a good chance of recovering your deleted data, but you need to take immediate action to prevent permanent loss.
Immediately stop using the storage device. Do not continue taking photos, downloading files, or installing applications. New data will overwrite deleted files, making them completely unrecoverable. Steps: Unplug the SanDisk dual-drive/USB drive from your phone, or if the data is on a microSD card, securely remove the microSD card.
Download recovery software on your computer and perform a deep scan: Connect the SanDisk device (microSD card or dual USB drive) to your computer.
Use reliable data recovery software to scan the drive, preview recoverable files, and then save them to your computer’s local hard drive.
Also, please note that Memory Zone 1.0 v4 is no longer supported. After data recovery, it is strongly recommended that you upgrade to the latest SanDisk app from the Google Play Store for subsequent backups. Further reading: Memory Card Deleted Files by Itself or Files Keep Disappearing
