How to Daisy Chain Pro-Blade Station?
Hi Everyone,
Am setting up Pro-Blade dock on desk and would like a total of 5 MacBook pros to be able to access it.
It mentions in the user manual on website you can daisy chain a total of 6 Thunderbolt 3 devices.
  • Should I use USB C to USB HuB to allow ProBlade visibility on MacBook screens?
  • Or connect via server network? (This has been mentioned, but not sure how it would work)
  • Or is there another way to explore?
Many thanks in advance!
L
Hi @Lukework,
Hi @Keerti_01,
Where do you open a Support Case?
Thanks
