I plan to apply raid-0 to multiple my book pro to get high transfer rate. Can i raid multiple my book pro ? for example when connect 4 my book pro together (daisy chain), can i raid them into single drive ? how good is the speed performance ? if yes, how big difference the raid speed when i use thunderbolt2 compared to usb 3.
How fast will i get from above case. Any solution if i want transfer rate above 900MB/s ? i need to playback 24fps realtime using dpx image sequence 4k 16bit (each file is 54MB).
