I have a TGZ file that I need to extract and convert to a usable format (such as ZIP or TAR). I’m not very familiar with TGZ files, and I’m unsure how to go about this. Can anyone suggest an easy solution or tool to convert TGZ files into a more accessible format?
Any guidance would be greatly appreciated. Thanks!
@Millswoods01TAR is a unix/linux archive. Z means it is compressed or zipped. TGZ means the file is tarred and zipped. So basically you just need to Unzip with a software capable of that format. Try 7Zip if you’re using Windows.
