eurika! i can access my song transfered tru MTP on MSC mode!
try this… it might be just my computer…
post if you experience the same thing.
- format the player to make sure there’s no other songs transfered thru MSC
- transfer a playlist to the player using MTP mode
- unplug the player and which to MSC mode
- plug the player back to the computer
- go to run and type ‘cmd’
- type ‘x:’ (where x is the drive letter of your mp3 player) press enter
- type ‘attrib /s /d -s -h -r’ (this will set the attribute of all the files and folders so you will be able to view it)
- open the ‘music’ folder in you player and look if you are able to see the songs transfered thru MTP
