How do I uninstall Sansdisk Unlocker from my 4TB external SSD?
Help! I urgently need to remove this. I’ve tried downloading SecureAccessV3 and installing it onto my SSD, but it will not run properly.
How can I remove the unlocker?
Hi @mikeb55,
To remove the SecureAccess Unlocker from your SSD:
  1. Backup Data: Transfer any important files from the SSD to another location.
  2. SecureErase Tool: Use the manufacturer’s utility (e.g., SanDisk Dashboard) to securely erase and reset the SSD.
  3. Manual Deletion: If SecureErase isn’t an option, connect the SSD to a computer and manually format it via Disk Management (Windows) or Disk Utility (Mac).
I also looking how to unnistall sandisk unlocker.
