The Rockbox utility says there is some sort of target mismatch so apparently I have to do it myself. Where do the files go? I looked on the website but its vague… I did get Rockbox installed however. I’d like to try new themes! Thanks
Un-zip the theme files to the .rockbox folder on your player. It will extract all folders/files to the right locations.
Thanks for the suggestion - I tried that and they still dont show up on the player. I dont know what the issues is…
If the theme was zipped in the normal manner, it contains the entire directory structure needed, including the .rockbox folder. After unzipping, just drag-and-drop the whole enchilada to the root directory.
Message Edited by gwk1967 on 01-26-2010 01:01 AM
Cool! It was just a matter of the files being in the wrong places. Thanks!
