Hello. I am looking to learn how to use the utility software on my G-Speed Shuttle (32TB) from RAID 5 to RAID 0. I need all 32TB available to me.
Thanks
Thanks
You need to log into the Studio software by clicking on the padlock.
Then you need to go to the Disk Array tab and delete the existing array.
Once that is gone you can go to the Wizard and click Advanced. From there select the drives and click Next. Then choose the RAID you want, in this case 0. Click add and continue through the rest of the Wizard. Once you click Submit at the end the RAID will be configured and formatted and mount right away ready for use.
Thank you!
