How can I see what has been backed up
After doing a category BU to my WD Passport Ultra, how can I see what was backed up? The Smartware tells me that what I selected was done.
But how and where can I confirm this?
Thanks
growlybear
Simplest way is to open the drive in Windows Explorer, then in the root you should find a folder WD Smartware.stor. Within that should be a folder for each device you’ve backed up, and within that a folder for each drive on that device that you’ve backed up.
Within those drive folders you should find the files/folders that have been backed up from that particular drive. You can look through them in the same way that you look through the files/folders on your actual drive itself, and confirm that everything is there that you expect to be.
