I’ve got a very strange problem with my Clip+ 8gb.
When I try to play mp3s on it I get an incredibly loud screeching sound, drowning out everything. I’ve tried both reverting to factory settings and formatting it, to no avail.
Stranger still is that I don’t get the screeching noise when I use the FM radio.
Anyone ever heard of this? I tried searching the forums but found nothing similar.
All mp3s or just some of them? Could be bad or corrupted files, or else something wrong with the players DAC (the FM radio doesn’t go through the DAC since its an analog device).
I think I remember reading that someone had this problem when the comment field was filled in. Try getting rid of the comments. Make sure that your tags are otherwise okay.
My Clip Jam suddenly did this yesterday for no reason! The high-pitched screaching was very loud & only in the left channel. I immediately stopped the song & then pressed play, and all was ok again. It’s been fine since then…
