The Clip supports 22 languages, I don’t think Hebrew is among them. The last language on the list could be Hebrew but it looks more like a Southeast Asian language.
Take the latest firmware file and rename it so that the last character is an “H”, put it on the Clip manually, and you’ll have Hebrew with FM radio enabled (if your Clip has radio hardware support).
There’s a sticky thread on the ABI forum that describes what all the letter codes mean…
Going back a couple posts - note that if you want your MP3s to display the track information in Hebrew (not just the Clip menu texts), I do believe you’ll need to use id3 v2.3 tags with Unicode (UTF) encoding. There’s info on doing that here on the forum.
You’ll need a tagging utility like MP3tag or, “whatever”. There’s several good ones.
Note that you can batch convert the files you have now to add/update the tags to unicode, you won’t need to do it manually or one by one…
