i am using wd my passport model no:WDBACY5000ABK-EESN 500 GB…now while plugging it to my lap its showing…“installing device driver software” and in that DISK DRIVE FAILED & WD SES DEVICE failed…am using windows 7 os…what to do ?can anyone help me with an answer…
Does it work with your desktop pc? If it does it might be a power issue. You could contact WD to see if a power booster is required.
If that’s not the case you can try :
- a different port on the laptop
- Uninstall and reinstall the drivers on device manager
- restart the computer and retry.
- Check on Disk Management and see if shows unknown or unallocated
- Try updating Firmware and downloading drivers
