I am thinking about buying a fuze, but i need to know if i can use regular headphones. I cannot wear ear buds, i have a ringing in my ears and something in my ear makes it worse.
You can use any you want, provided they have an 1/8th" or 3.5mm (same thing) sized plug, or an adaptor for it. Some of your higher-end cans might have sme pretty high impedance though, so a headphone amp may be necessary.
You can use any you want, provided they have an 1/8th" or 3.5mm (same thing) sized plug, or an adaptor for it. Some of your higher-end cans might have some pretty high impedance though, so a headphone amp may be desired and/or necessary. |
I like to use my big SkullCandy headphons for when I want to do some metal, headbanging, blast-the-roof-off-loud music. Any 8th inch headphones should work. You should use some with Stereo plugs (The ones with the two little black stripes on the plug) if you want the “surround sound” feel with the base and drums more prominent in one phone and vocals/lead in the other.
I use, and personally recommend, Sennheiser PX100 or PX200 (they are both on-the-ear, I can’t stand anything inside my ears).
