Hello, I just got my Clip yesterday and am loving it majorly but don’t understand what the “GoList” is for. Couldn’t find it in the user manual (or the online one either) so if someone could explain what it’s for, I’d much appreciate it. Also, I just found this forum and am pretty jazzed about ripping CD’s directly to the player as opposed to the drag & drop method, as explained in that other thread here.
Edit- Nevermind! I found another thread with my answer.
btw, I’m using a different pair of 'phones to listen to my Clip and it sounds even better than with the other (cheaper) pair of earphones I was using. These are full-sized headphones so I look kinda silly listening with them on and hooked up to such a tiny player, but it sounds cool!!
I do have another question - is there a thread here where anyone is posting the songs they’ve got on their player?
what use would a song thread be? the on the go list is seriously lame… go to the feature request link add your name there…
and for the bookmark feature request
There are a bunch of different software programs that do this; I use StationRipper. Just put your Clip into MSC mode, and then set StationRipper’s output directory to [drive-letter]:\MUSIC.
I never save any of the songs I rip. If I like one, I buy it from amazon.com.
I will probably stop recording directly to the Clip, though, now that I know it has a relatively short screen life. At least until Sandisk releases a firmware version that lets you shut off the screen while connected to USB.
Message Edited by PromisedPlanet on 01-07-2008 01:21 PM
Though actually, now that I’ve found out that the Clip’s screen life is relatively short, I may no longer record directly to the Clip. At least until Sandisk provides a firmware version that shuts off the screen while connected to USB.
