Does anyone know if the Fuze+'s radio relies on the sansa headphones that are bundled with it?
The headphones double as the radio antenna, but it doesn’t have to specifically be the Sansa headphones. Any pair will do.
If you have sufficient signal, the RDS data is available as well. You can see the album and artist information while listening.
Bob
reception ■■■■■ with my earbuds will connecting the USB cable jusy to the Player and nothing else help at all?
Don’t know how it would. The unit uses the headphone cord as the antenna, not the USB cable.
was just making sure.
