Can you use an iPod speaker/audio cable (through headphone jack, not USB) to connect the Fuze to a stereo system? I’ve heard of major issues with other MP3 players.
As long as it’s a standard headphone/speaker cable (and not something like the oddball headphone cable on the original iPhone), I don’t know any reason why it wouldn’t work.
Yeah you can. They are universally compatable. What you need to play with is the volume levels of both the fuze and the stereo to find what sounds best and what is safest for your stereo. What you cannot do is use a USB jack to do this but a 3.5 mm from the headphone out to what ever input you stereo has should be fine. Also make sure you push the jack in all the way.
