ao0921
1
I got 8GB Sansa Fuze as a present last week. I loaded it with my favorites… it worked fine.
Just now I connected it to computer downloaded SansaUpdaterInstall.exe and it installed update for firware and media converter.
Fuze showed that its installing new firmware… and everything was fine untill I watched a video on it and connected to a usb.
But it never did connect… it only is showing 4 colored petels and stays that way.
Is there a way to reflash firmware to previous version?
7o9
2
You can manually restore to any version.
Look at this page under ‘MSC mode instructions’: Sansa Fuze Firmware Update 01.02.26 & 02.02.26
Edit: changed link to firmware 0x.02.26.
Message Edited by 7o9 on 12-11-2009 02:45 AM
The update may have switched the USB mode to Auto Detect. And when you downgrade it will do the same.
Go to Settings/System Settings/USB Mode and try MSC or MTP. One of them will probably be the same as your previous connection.
ao0921
4
Thank you guys,
I could not load the fuze to get to USB mode.
So, removed microSD card and restared 2 times - that worked.
After getting to USB mode and doing back to fuze02.02.26 it works fine.
