HDD tests as Perfect. Disk Management says-- Disk 1 Unknown. Not initialized.-- When i try to initialize it says— Data Error ( cyclic redundancy check).-- I dont need to save the data, I just want a clean HDD, but I cant initialize or format it.
Can any one help please
Regards Derek
Hello, dereko,
Well I would recommend you to check the warranty of the hard drive, for checking the warranty status of the drive please click on the link.
https://support.wdc.com/warranty/warrantystatus.aspx?lang=en
and if it is under warranty, please try contacting WD’s Technical Support about this.
http://support.wdc.com/support/case.aspx?lang=en
No good. I am informed that it is an OEM and WD do not warranty them.
