I’ve been having some trouble with the SMC crashing on my PC, and needed an alternative. Since the Connect plays 3GP videos, I did some Googling and found a 3GP converter here: http://www.nurs.or.jp/~calcium/3gpp/.
I was able to transfer videos to my Connect using the following steps:
1) Download the converter from the above page. (The download link is in a green box. Click on the filename “3GP_Converter034.zip.” Don’t worry that the page is in Japanese. You’ll have the option to select your language when you install the converter.)
Unzip the file to whatever folder you want.
Run the setup utility.
Select your language from the bottom left dropdown.
From the configuration options, select the second option. (General 3GP2+AAC General Setting (w/o 3PP2 header)
Click Apply. The converter will now launch.
Select an output folder on your hard disk.
Select the following option from the dropdown menu: “QVGA High Quality 15fps Stereo”
Drag a video file to the window labeled “Drag&Drop” files here.
When processing is complete, go to your output folder (selected in step 7).
Rename the file making certain you change the file extension to .mp4.
Drag the file to the video folder of your Connect.
That’s it! It’s working for me, but of course YMMV.
Just thought I’d share.
