I need to record 2 radio programs each 4hrs. long. Is this possible with the “FM record on the fly” system? What is the maxium record length in FM mode, as it records in WAV format?
it doesnt tell you how much time is left when you are creating the recording?
Mine says a tad over 8 hrs available on the record screen - c250 ver2. using just the built in 1GB available.
Have you gone to the record screen?
probably not, or he wouldn’t of asked. Unless its different on the V2’s. But I doubt it
