I have a one gig express and i get 2 hours of FM recording. I bought an expansion slot hoping to be able to double that but it seems to look at each gig as seperate so two hours is still the max even though i have 2 gigs now…am i missing something??
Well when i had a similar issue, I contacted the Technical Support line and found out that it can only record 2 hour increments. So i guess if you recorded for two hours saved and then recorded another two hours then you should be fine.
thanks i thought that might be the answer…maybe an enhancement request…
