My sansa clip has FM radio stations ranging from 70 to 90, but the stations I want to listen to are in the 90’s and 100s such as 103.7. Is there a program that I can download to increase the FM range of radio stations?
Thanks,
Tmote
Thanks,
Tmote
Thanks,
Tmote
Check to make sure you have the right FM Region setting. I’m assuming you’re in the US. Do the following:
Power on the Clip
Press the Home button
Scroll up or down till you see Settings
Press the center Select button
Scroll up or down till you see FM Settings
the top line should read “FM Region” with either “USA” “Japan” or “World” (probably Japan based on the frequencies you say you can tune to)
Press the center Select button until “USA” is shown
Scroll down to FM Radio
You should now be able to tune to your desired station. If not, what firmware version are you using?
