Hey,
I have sansa clip plus 8GB and the fm radio statuons were OK up to the point that i decided to check the setting,and change the Fm settings to USA region and than back to WORLD but it skips by 5: 95.5—96—96.5… if it is changed back to USA(i dont live in the USA) it skips by 2 odd. 97.7—97.9.
How can i chane it to be accurate? i need stations like 88 or 88.2…
I looked in the searching options, tried to change the system setting----reset factory setting----yes—english—rest of the world.
but it dosen’t help.
Do you have any idea what sould i do?
Thanks!
