Good afternoon. Tell me where you can find the update firmware for the SanDisk X300s Solid Satet Drive? Version x2180300
please check in SSD Dashboard software
this program I have installed on the computer. It showed that needed updating. But it does not download and asks you to specify the path to the file with the firmware
Thank you Khopin,
In this case I suggest you contact our support center and create a case there, we may need more information like detailed system information, screenshot, drive information to do more troubleshooting
The difference between the SanDisk X and the Z series which is showing the ability of their own respective features and the function is totally different with their names and further, if you need more information you can bet through dell printer supportwhich will be giving you the best information.
@chushi wrote:
Thank you Khopin,
@britany wrote:
@chushi wrote:
Thank you Khopin,
In this case I suggest you contact our support center and create [Dafont 192.168.1.1 FileHippo](Dafont 192.168.1.1 FileHippo)l] a case there, we may need more information like detailed system information, screenshot, drive information to do more troubleshooting
@britany wrote:
@chushi wrote:
Thank you Khopin,
In this case I suggest you contact our support [Dafont Showbox FileHippo](Dafont Showbox FileHippo) center and create a case there, we may need more information like detailed system information, screenshot, drive information to do more troubleshooting
The firmware upgrade is applicable to the following X300 SSD SKUs:
• SanDisk X300 SSD M.2 2280 128GB
o SD7SN6S-128G
o SD7SN6S-128G-1122
• SanDisk X300 SSD M.2 2280 256GB
o SD7SN6S-256G
o SD7SN6S-256G-1122
• SanDisk X300 SSD M.2 2280 512GB
o SD7SN6S-512G
o SD7SN6S-512G-1122
• SanDisk X300 SSD mSATA 128GB
o SD7SF6S-128G
o SD7SF6S-128G-1122
• SanDisk X300 SSD mSATA 256GB
o SD7SF6S-256G
o SD7SF6S-256G-1122
• SanDisk X300 SSD mSATA 512GB
o SD7SF6S-512G
o SD7SF6S-512G-1122
• SanDisk X300 SSD SATA 2.5" 7mm 128GB
o SD7SB6S-128G
o SD7SB6S-128G-1122
• SanDisk X300 SSD SATA 2.5" 7mm 256GB
o SD7SB6S-256G
o SD7SB6S-256G-1122
• SanDisk X300 SSD SATA 2.5" 7mm 512GB
o SD7SB7S-512G
o SD7SB7S-512G-1122
• SanDisk X300 SSD SATA 2.5" 7mm 1TB
o SD7SB7S-010T
o SD7SB7S-010T-1122
Admin
