cccv
December 13, 2011, 1:28pm
#1
Hello everybody,
Revently buy a Sandisk Extreme Pro SDHC-I 45mb/s SDcard. Probarly a fake.
I didn’t know they fake this type already…
How can I be sure to check or the card is phony? At the back is a serial number would it be useful if I post that?
Bye Cornelis
cccv
December 13, 2011, 3:12pm
#2
I have testet the card, it shoul had a speed of 45mb/s but this is the result, it normal?
Test finished without errors.
You can now delete the test files *.h2w or verify them again.
Writing speed: 15.4 MByte/s
Reading speed: 18.7 MByte/s
H2testw v1.4
drlucky
December 13, 2011, 10:10pm
#3
it depends on what type of reader you are using. this is a UHS-I card. to get the full speed you will need a USH reader. the only 2 sandisk make are linked below. If you are using a regular USB reader the speed you get is correct.
http://www.sandisk.com/products/readers-accessories/sandisk-extreme-pro-express-card-adapter-for-sdhcsdxc-uhs-i-cards
http://www.sandisk.com/products/readers-accessories/imagemate-all-in-one-usb-30-reader
cccv
December 14, 2011, 9:58am
#4
Oke thanks for the reply, here are also some pics, does it looks o.k. form the outside as an orginal?
](http://i42.tinypic.com/rkbggh.jpg[/IMG] ) the box
](http://i43.tinypic.com/1zdbxhz.jpg[/IMG] ) front of card
](http://i44.tinypic.com/9sfn81.jpg[/IMG] ) back of card (has also a serialnumber wich is not good to see at the picture)
drlucky
December 14, 2011, 3:55pm
#5
the angle of the picture does not show the codes printed on the card. best way to confirm is to contact sandisk support
http://www.sandisk.com/about-sandisk/contact-us?utm_source=ContactUs&utm_medium=Hyperlink&utm_campaign=HomePageTracking
cccv
December 14, 2011, 5:05pm
#6
I have contacted the support desk.
This card seems to be 100% genuine, lucky! The serialnumber was o.k.
